390 Oil Leak Blues
1 reading
20K views 7 replies 6 participants last post by  cyclone gt
#1 ·
I have a 71 F100 with a 390. The motor was rebuilt about 5k ago, and not long after started leaking oil from the back of the motor, most prevelant on the passenger side. I figured it was a rear main seal problem. I replaced it twice with no effect. Both times with neoprene seal. I inspected the crank, it was in good shape with ////// marks. I thought about the intake causing the leak, so redid it with no effect on the leak. Any ideas where my problem is? Could it be the camshaft/oil gallery plugs or am I way off on that? If so, would the flylwheel be covered in oil, cause its not? Some say I should live with it, but I don't like to see puddles under my truck or tons of oil grease underneath. I appreciate any ideas.
Tyler
#4 ·
Are you sure it's coming from behind the motor? Have you checked the valve cover gaskets?
Also make sure the intake is sealed,...not just on the flat edge of the block but the corner where the intake gasket meets the flat edge gasket. If you are using silicone or right stuff make sure that you have enough to seal the open gapped area.
#6 ·
I am currently investigating the same problem on my 1962 Mercury 390. I just rebuilt and installed the engine and its having the exact same problem and symtoms you are having. I dont understand how the flywheel can remain dry and still have oil leaking from inside the bell housing.
Ill let you know what I find. I dont think I have a choice but to pull the trans out at this point. Everything outside the engine is dry except the starter which appears to be supplying a partial exit for escaping oil.
